94 4.3.... coolant looked dirty
opened radiator cap, opened drain plug.
removed lower rad. hose
replaced thermostat+gasket
filled with prestone flush, rinsed 3 times, until water was clear.
Hooked everything back up and filled with coolant. top hose hot, lower hose hot but not as hot as upper.
10 minutes of idling top hose is rock hard(its a month old hose)
i used the funnel kit to bleed all air out, temp was all the way up to 260 on dash.
and no heat....i dont see how there could be an air bubble left. what else could cause that?
