Alright, well i have a 5gallon tank which is mounted in my bed and has a 1/2" port on the bottom that is currently plugged. I need to turn it into a drain so i can drain my tank. I was going to get a drain cock, but i think after the drain cock and a reducer fitting that it would be too long, the bottom of my tank is only an inch or so off the top the bottom of my bed. So i was thinking that i could just get a 90 degree angle fitting and then on the end of that put a shrader valve to use as a drain and for safety to fill my tank if my compressor ever goes out. Would the shrader valve at a 90 degree angle be a good enough drain for the tank? Let me know what you guys think.. thanks!
- Mike
- Mike
