Has anyone ever re-clocked there TPS and seen any horsepower gains out a 2.2. I know most cars see horsepower with this mod but i figured i check before i go drilling my TPS.
There is nothing wrong with my Tps. My truck has nothing but 17,000 miles on it and it very babied. You will never understand unless you know how to work with fuel and ignition maps. I guess i can say that i am not making more horsepower but retreiving horspower and torque that is already there however the computer never made use of. I dont really need to prove anyting to anyone on the forum. If you want to believe do so if you dont too bad. I know thsi work becuase i've been able to look into my fuel maps with a Gm tech 2. A tool that most people dont hhave readily available to them , however becuase i were i go to school i have both a dyno and the Oem scanner available basically anytime i need either one. Learn exactly how a tps work and learn about igniton and fuel maps and them you will understand.gutlesswonder said:so as i said there is no actual gain in hp. if anyhting you are regaining lost power do to a faulty tps sensor. if you have a low sensor output and you either boost the signal ie caspers you can regain your lost power or by "clocking" the tps you are making the tps out put the correct signal. i think it would be much better to just clean your darn tps. or for that matter just replace it so it functions properly. as stated by 964pt3 anyhting over 4.5v is going to give you a WOT signal. and this guiy had under the 4.5v threshold. so he gained a minimal hp because it was not far off. its just like replacing bad spark plugs or giving the old ones a quick squirt. you not really gaining hp your only getting back what you were missing from a bad part.
He gets it. its all about fuel and igniton tables that are in the Ecm but are never accesed becuase the Ecm is not receiving enough voltage to do so.964pt3 said:OK, your suppose to have a base reading for idle between lets say 1.0-1.4 volts for the ECM to understand your in idle. At WOT it must see 4.5 min in order to give you the max tune it can for both timing and fuel, but nothing over 4.8 volts since it must stay under the 5 volt reference input.
These TPS's are so generically made and incorrect you will find out after some testing that they can go below the 1.0 voltage min which the ECM unless its under by over 10% allows. On WOT I've seen times where 4.3-4.4 is the max it sees with the plate all the way open. Now in WOT which is anywhere from 75% to 100% open it grabs the tables for tune based off the voltage and disregards most of the sensor inputs at that point. It will not go to the full max tune table with a under 4.5 voltage reading, it doesnt know youve asked for it all no matter what.
Now on the V-8s of the Fbody types you'll find that their TPS' are adjustable so they can nail it completely to full max idle which in turn give them full WOT. Take the same appraoch to any other motor, it works, but only if it doesnt see 4.5-4.55 volts at WOT. You merely elongate the holes of the TPS to advance it. Take a reading with the key on for idle and WOT positions and adjust it just under what the bookcalls for for idle and then see where it lies WOT.
Caspers TPS-TEC addon and the $200 Module thing, forget the name of it, work off pretty much the same style premises. The Casper unit adds 5% to the signal for the entire RPM range till it see 4.2 volts then ups the signal to 4.7 at really 4.2. The other module plug in deal adds 10% to the signal until 4.2 volts then backs out and lets the true TPS reading take over!
I felt a un-nerving presence in the force and just had to respond.importmaster1300 said:Thank you OBI (964pt3)!
I am not trying to argue with you but i do understand how fuel maps work. but there is a bottom line here. the bottom line is your truck has those maps in the comp and your not able to acess those maps because your tps is not outputting the correct signal strength. what your doing is giving the tps a better connection allowing a higher signal to be transmitted to the comp. you say you dont have any faulty parts although you were not getting the correct signal strength you should be. i have tested mine before to make sure i was reaching WOT and guess what i was so not every truck will be the same. 1 truck may not reach WOT when another truck will right off the factory floor. i am in the process of fabricating my own turbo system for this little beast as we speak. if i did not understand "how things work' i wouldnt be doing this. but in all reality thnk about it its just like changing your plugs. if your truck was slow because plugs werent putting out the correct spark and you replace them you didnt gain power you got back what you were missing in the first place. my truck is not missing that. i have run faster times n/a then probably every person on this board. not a single person has posted any times slips or proof to run faster than a 17.3 n/a. i have raced members with better or sinilar mods to mine and still took them by over a second. so if you do these tests and see your not getting 100% throttle then this is a good mod but if you are reaching WOT then there is no need to do this mod. over all i guess if i didnt already achieve WOT then id try it that is for sureRed 2.8 said:There is nothing wrong with my Tps. My truck has nothing but 17,000 miles on it and it very babied. You will never understand unless you know how to work with fuel and ignition maps. I guess i can say that i am not making more horsepower but retreiving horspower and torque that is already there however the computer never made use of. I dont really need to prove anyting to anyone on the forum. If you want to believe do so if you dont too bad. I know thsi work becuase i've been able to look into my fuel maps with a Gm tech 2. A tool that most people dont hhave readily available to them , however becuase i were i go to school i have both a dyno and the Oem scanner available basically anytime i need either one. Learn exactly how a tps work and learn about igniton and fuel maps and them you will understand.
Well with 4.3 volts my TPS wa reading 97% load.erronisme said:hypathetical question.
If you had 4.4volts at the TPS
and plugged in a scanner to read the percentage, would it read 99 or 100%
What happens after the 4.5? What if it does reach 5 or more volts?
And since the TPS is just a potentiometer, what is the input voltage that crosses the TPS?
Is this input voltage to the TPS the same for every vehicle?
964pt3 said:It has to read 4.5-4.55 Volts for the ECM to use 100% open throttle timing table. Fuel wont be 100% until over 4.6 volts. QUOTE]
Had to read that part twice....
Ok, so when the ECM is getting 4.5-4.55 volts from/ threw the TPS then it is using a 100% TIMING table.
But the ECM is not running the 100% fuel map until it reaches 4.6 - 4.8 volts.
However, if the ECM reads 4.9 volts or more then it thinks there is a short.
:idea: and the little light bulb in my head just went click!
Ok, so that part is all figured out. Now I need to justify whats going on.....
I would assume that the reason most, if not all, vehicles wont go up to 4.6 volts is because its one of those precission things that a factory doesnt have time to set.
The second thing that I want to figure out....
Where can I find a more crediable source?
Not to bash any one person, but getting any information from an on-line person is not as reliable as what you could get from....lets say a book or a reputable manufacture web site or something.
erronisme said:I got this information from two teahcers at my school. DR Duane Watson and Mr Ty Cobb one is the head of my Hot Rod program the Other is the Head of the Hot Rod program of The UTI campus in Glenndale Heights Illinios. The both have been in the Automotive feild for many years and are both ASE master certified. Dr watson has even been Pontiac and Buick Tech of the year mamy times and at one point was very close friends with John Ligenfelter. Im not getting this information from some dude sitting in front of the computer. They're reliable sources.964pt3 said:It has to read 4.5-4.55 Volts for the ECM to use 100% open throttle timing table. Fuel wont be 100% until over 4.6 volts. QUOTE]
Plus i've learnd alot more about the subject i just dont know how to explain it.
Where can I / we get more information?Red 2.8 said:Plus i've learnd alot more about the subject i just dont know how to explain it.
