Resident A-10 Crewcheif
Location: Springfield,MO and Whiteman AFB,MO User is: OffLine ![]() |
Project: Clean, cut, rebuild, and save some damn cash.
My overall goal with this is to rebuild the engine, and get it ready to accept the hydrogen fuel cell thing that I built, clean up all the grease and oil, powdercoat some stuff, redo the wiring, and tub the drivers side. I will also be doing some gasket matching, porting, and polishing.
Here is what I am working with: ![]() Replacing the timing chain and gears: ![]() Something is wrong here lol: ![]() Its nasty under here: ![]() The reason for my engine being torn down. #2 is off a little, in turn its causing a misfire on all cylinders. ![]() ![]() ![]() Gasket pieces: ![]() |
Re: Project: Clean, cut, rebuild, and save some damn cash.
On to the head:
This is how wide everything needs to be: ![]() This before any mods: ![]() The gasket: ![]() Before pics: ![]() ![]() ![]() ![]() ![]() Its going bye bye!: ![]() During and after pics: Valve cover (Powdercoated with metal flake): ![]() First exhaust port: ![]() ![]() Its closer than that now that its polished: ![]() Cleaned the valves (before and after): ![]() ![]() Finshed and needed to be tested then powdercoated (chrome): ![]() ![]() ![]() ![]() This is how my truck looks currently: ![]() ![]() |
I'm SOL and JWF!
i say may as well take the fenderwells out while your in there. looks pretty good if you ask me.
Did some powercoating and painting. I got the head back from the machine shop, I had hem glass bead it, then I painted it.
![]() ![]() ![]() ![]() ![]() ![]() Last edited by ablues10 : 08-02-2008 at 03:36 AM. |
I finished pulling the motor today. I went to unbolt the exhaust and found this:
![]() Anyways. I started disassembly. ![]() ![]() ![]() ![]() ![]() ![]() Im starting inital combat with some foaming degreaser. ![]() Nasty pistons: ![]() Good looking clutch! This has been in since Jan. : ![]() ![]() |
holy s@#$ cuz i need to get over there...sorry i couldent make it today
not low enuf
were did you get that clutch? what year is your truck
I had it build by a race shop here in Springfield. It costs 180.00 for just the disc and it holds up to 700HP My truck is a 98 |
V8 with bags
those rims/tires look huge, what size are they. Engine looks nice. Just a rebuilt with a little head work or more. Either way looks good
nice work you did on the engine..
your blowerbox looks good! |
is out cruisin...
awesome detail on the engine man...GL with gettin the rest all back together
I did a little more today. Every power wire has been stepped up to a minimum of 4 ga. All main grounds are 4 ga. The engine to frame is 1/0, the main batteries are 1/0ga, and the alternator charge wires are 1/0 ga. I did some more work to the speaker box and its gonna be sick! |
Used Midget Dealer!!!!
Location: N. Little Rock, Arkansas User is: OffLine ![]() |
Looks good.
Update!
![]() ![]() ![]() Fuse box is wired and mounted. I hope to start it in a day or 2. Fenders are on for good. No more removing them lol. |
Woo!!! I started this bitch yesterday! Now I can put the front end together. I have to tighten up some stuff and then it will be on to the interior!
Drop and Destroy
bad ass truck, i hope my engine looks that clean. did u powdercoat or paint the intake manifold?
No, the intake manifold is spray painted with high temp engine paint.
GET LAYED!!
looks awesome man!
did you ever get around to tubbing the firewall?? |
