Im going to hijack this just a bit but its the same as the OP. I have a reg cab first gen and Im looking to build a subbox but with the lack of space I want to have two 10s or two 12s to be powered by my amp. Im not looking for the biggest db hit or anything, but i want to have a nice sound and quality and it be the best bang for the buck. My amp is a Eclipse da7122 digital amp. Not sure if ayone of you guys have had one or know of it but from wat i recall it was a peak power of 1000w I believe. Dont hold me to it. But anyways. What would be a good combo for a shallow mounted subs (rather have 10s but if 12s suit the amp better than i will go with it) for my amp and regular cab status?
Product MPN
MPN DA7122
Key Features
Amplifier Type
http://www.s10forum.com/xWI?lid=1&fid=420&aid=5417Mono Channel Bridgable
http://www.s10forum.com/xWI?lid=1&fid=420&aid=5442Not Bridgable RMS Power at 4 Ohms 500 W x 1 RMS Power at 2 Ohms 1000 W x 1 3 Way Ready No
Performance
Frequency Response 4 Hz - 3000 Hz Signal to Noise Ratio
http://www.s10forum.com/xWI?lid=1&fid=420&aid=5435120 dB THD at Rated RMS Power 0.01 %
Crossover / Equalizer
Low - Pass Frequency 50 Hz - 200 Hz High - Pass Frequency 50 Hz - 200 Hz
Other Features
Input Voltage 10.8 volt
Dimensions
Width 15.75 in. Depth 11.85 in. Height 2.05 in.
Miscellaneous
Product ID 20713886
Product MPN
MPN DA7122
Key Features
Amplifier Type
Performance
Other Features
Dimensions
Miscellaneous
Product ID 20713886
Product MPN
MPN DA7122
Key Features
Amplifier Type
Performance
Other Features
Dimensions
Miscellaneous
Product ID 20713886
Product MPN
MPN DA7122
Key Features
Amplifier Type
Performance
Other Features
Dimensions
Miscellaneous
Product ID 20713886
Amplifier Type: Mono Channel
Bridgable: Not Bridgable
RMS Power at 4 Ohms: 500 W x 1
RMS Power at 2 Ohms: 1000 W x 1
http://www.shopping.com/xPO-Eclipse-DA7122
