Well My heater core started leaking so I figured w/e I need to pressure wash carpet, which turned into lets remove my entire interior.
It's not bad looking I have fairly minimal rust, a few spots I've grinded deeper than I'm confertable, but all in all it's just maybe .01% of my floorboard has any rust. The front carpet piece is nasty, so now I'm just thinking of pressure washing my plastic pieces and maybe my floor.
Any thoughts on por 15-ing the floor? I mean with only one side of the metal getting it, where as the original inside paint is for the most part decent.
As you can see in my roof pictures, whenever gm advertises their cabins have sound deadening... well, by that they mean 4 small squares of peel and stick in random spots, with no correlation. So I'll probably be re-insulating the entire truck as well, any suggestions as a good cheap insulation (rust inhibitive if it exists b/c the muffler insulator trapped a little bit of water)
Also I noticed one of my driver seat studs has a crack going around it about 150 degrees or so, kinda wierd, guess I'm going to have to tig weld it back togethor. other stud surroundings also have small cracks, but w/o further ado
Here you can see the original headliner color vs the color it is now, quite a transition
Oh, and those dots you see everywhere are just bits of tar/window sealant they spilled from the factory, in case you wondered (not rust)
