4.3 mercury marine vs standard 4.3
19K views 9 replies 8 participants last post by  Rhotpursuit
i have a boat with a 91 4.3 merc that either has a cracked block or head.
'' the motor fill's up with watet a few minutes after leting it run.
I guess my question is whats the diference between the 2 besids the cam? Would it be safe to re-cam a 4.3 from my v8 s-10 swap it runs strong and just sitting in the shop
#2 ·
I have been told some marine engine turn backwards in rotation than a normal car engine. maybe someone will chime with more marine experience.
#3 ·
Bottom ends are slightly different . I know they come stock studded. In 94 and 95 the 4.3L had a HD block which ran a really have casting compared to earlier marine and car blocks.
#5 ·
Twin I/O setups have the second motor spinning reverse rotation, to reduce cavation of the impellors. So any boat that came with twin 4.3's (if there were any) would have had one rotating in each direction.
To the OP, you need to change the head gasket to use a truck motor in a boat, unless you're only going to use it in fresh water
#6 ·
There were a lot of boats that used two GM 4.3L motors but were labled as Volvo.
