Q1- Can the stock engine take the boost if i use a mild 8psi or so? Should i go ahead with it if i can do it b/c it's my daily driver. (i wouldn't be needing it during the process)
As long as fuel and spark requirements are met, 8PSI or so on a stock 2.8 should be fine. I'm not going to get into how the whole "XX PSI" is really not a good value to use here.
Q2- how much will it cost overal if i buy parts seperately and do it myself. Such as a used holset off ebay for 150-300 bucks(T3 or so, but i'm new to turbo's). any other suggestions for the turbo welcomed
More than $0, is about ass accurate as any body on here can be. Depends on what parts you get for how much. I've put turbo systems together for a couple hundred, I've also spent several thousand, there are a lot of variables.
Q3- What changes have to be made to the fuel system? I've heard of changing the Fuel pump, but if i ran mild boost could i just use 4.3L or 5.7L injectors?
Again, this depends on what you use and what you want to get out of the vehicle. Some low (HP) increase systems will be able to run on the stock pump, some will require a higher flow fuel pump. Injectors and/or fuel pressure changes will likely be needed, but there is no definitive answer here. When most people attempt to turbo charge a TBI system, they tend to use secondary injectors, for the additional fuel.
Q4- what ecm mods will be needed for the low boost if any?
Some or none, depending on how you go about controlling fuel and spark.
Q5- do i HAVE to tune the ecm and if so, how much does it cost?
You don't HAVE to, but it is beneficial. It's like the fact that you don't HAVE to eat green vegetables, but's beneficial in the long run.
Q6- What things have to be done in general such as the oil line etc? and wht is to be expected.
This is where some time spent researching, not only here, but elsewhere on the intarweebnetz, and dare I say it?, with your nose in a book would really help. There are some basics that apply to every turbo system, like the fact that the turbo needs and oil supply for cooling and lubrication, but exactly how that is accomplished can vary between systems. I tend to T-off the oil pressure sender for the supply to the turbo, and then return it from the turbo using gravity, which mans the turbo is mounted above the oil pan level , to the upper part of the oil pan. If the oil level doesn't allow the oil return to flow in above the static oil level, I will use an accumulation pan/box, that will then allow the frothy oil to return to an oil state before re-entering the oil pan.
Thank you guys for you time and i think that there should be a turbo and 3.4 sticky for future seekers so these posts aren't required.
There isn't a sticky, because the information is out there, and when you start with something like an S-10 there are so many different ways that people would accomplish turbocharging their trucks, that a single sticky couldn't contain all the information needed.
Also in the end, people tend to swap to MPFI, since it is so much easier for fuel delivery, and air flow than using TBI.
If you want to stay TBI, the '7730 (which was available in a number of platforms, including the F-body, but also many FWD applications such as J-body, L-body, etc.) would not be my first choice, due to the hardware fueling control that is used by these ECMs. I have toyed with the idea of running a TBI system from a '7727/'7730/'7749, but haven't had time to set it up on my test bench yet. The reason the '7730 would not be a god choice is there are no factory TBI set-ups that use this ECM to my knowledge. TBI and port injection have different firing schemes for the injectors. The TBI will fire on every DRP (Distributer Reference Pulse), where as port fires on every other DRP (in sync mode). To change this requires both a software change (which is in the "chip"), and a hardware change, that is changed with the other half of the MEMCAL. At present $58/$59 (Sy/Ty code and modified Sy/Ty code) has not been used with TBI successfully, to my knowledge.
I would, if I thought that turbocharging a TBI was going to do what I wanted, go with the Dynamic EFI EBL, since it has a whole bunch of functionality that the original ECMs for these trucks didn't have, including support for 2 and 3 BAR MAP sensors in addition to the original 1 BAR MAP sensor.
S0_l0W said:
if you can find a high flow oil pump for the 2.8 you could put a t fitting before the oil sending unit and the pump would feed the turbo through that secondary on the t fitting
Not needed, the stock oil pumps flow enough as it is.
