so.. i got this 4.3... ive been doing a lot of work to it recently and i have sort of a delima...
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:2,000-5,500 RPM
Intake Duration 050 inch Lift:215
Exhaust Duration 050 inch Lift:220
Duration at 050 inch Lift:215 int./220 exh.
Advertised Intake Duration:270
Advertised Exhaust Duration:276
Advertised Duration:270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.500
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.510
Valve Lift with Factory Rocker Arm Ratio:0.500 int./0.510 exh. lift
Lobe Separation (degrees):114
ok and then i got these pistons
Bore (in):4.030
Piston Material:Forged aluminum
Piston Style: Dish
Compression Distance (in):1.562
Valve Reliefs:Four
Wrist Pin Style
ress fit
Pin Diameter (in):0.927
Top Ring Thickness:5/64 in.
Second Ring Thickness:5/64 in.
Oil Ring Thickness:3/16 in.
ok, now i actually got a cam/timing set from compcams ($903!)
it came with springs, lifters, rods, CAM, and the timing set. ok. Now I have a Question...
I plan to Twin Turbo this motor. What Turbos should I run with this setup? Fuel management and ignition systems. from my understanding with my volvos, if i want to run mechanical injection id have to use a vacuum advanced distributer. I'm not trying to run 15+ psi or anything crazy, im trying to make a nice tuned car that will give me a lot of enjoyment. Throttlebody modifications neccessary? I have aluminum heads, stock. I have a huge intercooler. Any input would be greatly appreciated. thanks =)
Bore (in):4.030
Piston Style: Dish
Valve Reliefs:Four
Wrist Pin Style
