S10 - Fender Removal
62K views 3 replies 4 participants last post by  KyleO
#1 · (Edited)
I did a search on this topic and was not able to find any related information so I decided to create this thread for those who may need some info in the future.
I had a damaged right front fender and found a nice replacement on CL that happened to be the same color. I did the replacement this afternoon. I thought I would write a "How to". Remember the instructions below are related to removing the passenger side fender. Should be similar for a driver side removal. Sorry, I didn't take any pics.
Tools needed for the job:
15mm socket, 3/8 drive
13mm deep socket, 3/8 drive
13mm gearwrench
13mm open end/box end wrench
10mm socket , 1/4 drive
2 long extensions, 3/8 drive
standard "blade" screwdriver
pliers
trim removal tool
You will need to remove the grill, headlight assemblies and front bumper. The grill snaps out, just be careful not to break the tabs when prying them out. I used a trim removal tool to pry mine loose. The front bumper is held on with six 15mm bolts, four on the front and one on the bottom side of each side. These bolts can be accessed after the grill and head light assemblies have been removed. The bumper has to be removed because each fender has a stud at the front that locks into the bumper. The fender will not release if the bumper is not removed.
The hood will need to be detached at the hinge on the side you plan to work on. This will be done using a 13mm wrench and 13mm gearwrench. If possible total removal of the hood would be prefered, but isn't required. To remove the hinge bolt the end of the cowl cover must be removed to access this area. The cowl is the three plastic pieces that cover the windshield wipers. This is done by removing the push pin, which looks like a philips screw. You can attempt to unscrew it, but most likely you will have to pry it or pull it out. Then unsnap the outer edge of the piece from the body.
The battery will need to be removed to allow access to a bolt that fastens the fender to the front support. Remove the ECM from the top of the coolant tank. This is done by removing three 10mm bolts. Push the ECM aside so that you can see the inside area of the fender. There are wire connecters that will need to be removed. I used my trim removal tool to pry the fasteners loose. You will need to disconnect the horn as well. Look at the battery tray area (battery removed) and you will see two silver 10mm bolts. These bolts hold a bracket with a couple of relays attached to the inside cavity of the fender. Remove these two bolts and the relays will come out. The last thing to disconnect will be the antenna cable. It simply unplugs.
Now you can move to the meat and potatoes which is removing the fender. Open the passendger door. Look into the area where the hinge is located. At the top you will see a 13mm bolt and at the bottom you will see another one. These bolts need to be removed. You will most likely need to use your 3/8 extentions put together to allow you access to these bolts. Crawl under the right side and you will find another 13mm bolt that fastens the bottom edge of the fender to the chasis. This bolt is important, mainly because I forgot to remove it and could not figure out why the fender would not come off. There are two more 13mm bolts on the top edge of the fender near the hood hinge. Remove these two bolts. There is one 13mm bolt near the battery tray that must be removed (mentioned above). There is a 13mm bolt on the top edge of the fender above where the head lights would be, remove this bolt. At the front bottom edge of the fender there are two 13mm bolts. One on the immediate front and one just below on the side. Remove these bolts. Next you will need to remove the 13mm bolts from the inner fender well that attach to the fender. These are accessed from the wheel well and can be done with out removing the wheel. Once these have been removed the fender should come right off. If it doesn't then check all bolt locations to ensure they've all been removed.
Remove the old fender and replace with the new fender. Do everything in reverse and you should have it all buttoned up nice. This job took me about two hours start to finish. I could probably cut some time off now that I've done it once. I tried to remove the fender without removing the front bumper and this added time. Good luck on the repair!
Reactions: Lango
#3 ·
You don't have to remove the hood if you unbolt the front bolts underhood first then close the hood. You also don't need to remove the ECM or coolant tank, just pop loose the wires that are held in place with clips to the fender. I didn't have any relays in my fender, just the horn. Here's a few pics of it torn apart.
#4 ·
Hi I have a '97 Sonoma. the fender, grille and headlight were badly damaged in an accident. your s10 fender removal thread was of great help in doing the repairs myself. I picked up some recycled parts, had them painted and put them in my self. I have some pictures and the dealership sent me some step by step instructions and detailed drawings to help the project along.
Kyle
2000 GMC Truck Sonoma Pickup - 2WD | Blazer, Bravada, Envoy, Jimmy, S10 Pickup, Sonoma (VIN S/T) Service Manual | Body and Accessories | Body Front End | Repair Instructions | Document ID: 553148
Front Fender Replacement
Removal Procedure
1. Remove the radiator grille. Refer to Grille Replacement in Exterior Trim.
2. Remove the hood bumper from the fender. Refer to Hood Bumper Replacement .
3. Remove the hood. Refer to Hood Replacement .
4. Remove the antenna mast and the base. Refer to Fixed Antenna Mast Replacement in Entertainment.
5. Remove the battery. Refer to Battery Replacement in Engine Electrical.
6. Remove the radiator coolant reservoir. Refer to Coolant Recovery Reservoir Replacement in Engine Cooling.
7. Remove the electronic brake control module from the fender. Refer to Electronic Brake Control Module (EBCM) Replacement (310 ABS) or Electronic Brake Control Module (EBCM) Replacement (325 ABS) in Hydraulic Brakes.
8. Remove the vacuum tank from the left fender. Refer to Vacuum Tank Replacement in Heating, Ventilation and Air Conditioning.
9. Remove the electrical harness retaining clips from the fender.
10. Remove the bolts that retain the fender to the radiator support.
11. Remove the bolt that retains the fender to the reinforcement.
12. Remove the bolts that retain the fender to the cowl.
13. Remove the bolts that retain the fender to the door hinge.
14. Remove the bolts that retain the fender to the rocker panel.
15. Remove the bolts that retain the fender to the wheelhouse.
16. Disconnect the wiring and the vacuum lines from the fender.
17. Remove the fender from the vehicle.
Installation Procedure
1. Install the fender to the vehicle.
2. Connect the wiring and the vacuum lines to the fender.
Notice: Refer to Fastener Notice in Cautions and Notices.
3. Install the bolts that retain the fender to the wheelhouse.
Tighten
Tighten the fender to the wheelhouse bolts to 29 N·m (21 lb ft).
4. Install the bolts that retain the fender to the door hinge.
Tighten
Tighten the fender to the door hinge bolts to 29 N·m (21 lb ft).
5. Install the fender to the cowl.
Tighten
Tighten the fender to the cowl bolts to 29 N·m (21 lb ft).
6. Install the bolt that retains fender to the door frame.
Tighten
Tighten the fender to the door frame bolts to 29 N·m (21 lb ft).
7. Install the bolt that retains the fender to the reinforcement.
Tighten
Tighten the fender to the reinforcement bolts to 29 N·m (21 lb ft).
8. Install the bolts that retain the fender to the radiator support.
Tighten
Tighten the fender to the radiator support bolts to 29 N·m (21 lb ft).
9. Install the radiator coolant bottle. Refer to Coolant Recovery Reservoir Replacement in Engine Cooling.
10. Install the vacuum tank to the left fender. Refer to Vacuum Tank Replacement in Heating, Ventilation and Air Conditioning.
11. Install the electrical harness retaining clips to the fender.
12. Install the electronic brake control module to the fender. Refer to Electronic Brake Control Module (EBCM) Replacement (310 ABS) or Electronic Brake Control Module (EBCM) Replacement (325 ABS) in Hydraulic Brakes.
13. Install the battery. Refer to Battery Replacement in Engine Electrical.
14. Install the antenna mast and the base. Refer to Fixed Antenna Mast Replacement in Entertainment.
15. Install the hood. Refer to Hood Replacement .
16. Install the hood bumper to the fender. Refer to Hood Bumper Replacement .
17. Install the radiator grille. Refer to Grille Replacement in Exterior Trim.
