Radiator
1.3K views 10 replies 5 participants last post by  K-Man
I AM GETTING READY TO PUT A '76 V-8 OUT OF A MALIBUE IN TO MY '87 S-10. I HAVE THE RADIATOR THAT WAS WITH THE MOTOR AND IT IS ONLY ABOUT 2 YEARS OLD NOTHING WRONG WITH IT. MY QUESTION IS CAN IT FIT IN PLACE OF MY 2.5 RADIATOR JUST WITH MINOR MODIFICATIONS TO MY TRUCK OR DO I JUST NEED TO GO GET A CORVETTE RADIATOR.
HELP ME OUT GUYS!:pimp: :confused:
#8 ·
webgator said:
Unless you're running a lot of horsepower, a factory 4.3 S-10 radiator will work without any mods. Depending on what mounts you use and where the engine sits you may also be able to use a flex fan instead of electrics.
finally someone that agrees with me. i am also running the stock 4.3 radiator in my truck, and it doesnt go much past 160-170 in this 95 degree heat. i have 2 camaro fans pushing btw..
#11 ·
If your 2.5L rad is an aluminum core (not copper) keep it, don't replace it. The 2.5L four banger rad has the hoses on the same side as a V-8 rad. The rad will work fine if you run a 195degree thermo and a good direct drive fan. Wouldn't hurt to put a pusher electric in front too, but not necessary. My buddy's truck has a V-8 with the four cylinder rad and it runs between 190-210.
