orange corner light/turn signal problem
784 views 6 replies 3 participants last post by  yungc1019
out of no where my turn signal on the left side started blinking fast and when its not on, it stays solid green on my dash. i checked the light and looked fine but replaced it anyways and still the same problem. the right side works fine and has no problems. any idea what this could be?
#3 ·
wouldnt be a wiring or ground issue? i will go check out the bulbs right now. i know the only one int he front not working is the oranger corner light, which isnt burnt out i already replaced it.
#7 ·
could be the turn signal switch.. there's only one way to test it too..
buy a new 1 for $500- $600 and test. if you still got the same problem return it.. i had the same problem on my old grand prix gtp and it turned out to be exactly that..
