Status
Not open for further replies.
41 - 47 of 47 Posts
Both the ZR2 fender flares and regular non-ZR2 flares are back in stock now.
So as far as rear Blazer/Jimmy flares fitting an S10 or Sonoma pick up, is it just the way that they are fixed to the body that is different? These Jungle Flares do not use the over-complicated metal frame in behind. They just mount through the underside lip of the flares into the inner fender like 99% of all other flares ever made. Point is, is the shape of the rear pick up panel/body the same as the blazer in the location of the flares? It sure looks like it from photos, even the wrap around bumper looks like the same shape.
It has been confirmed that the rear Jungle Fender Flares do fit on the Sonoma and S10 pick up. It seems to be the steel frame in the back of the originals that make them (Blazer vs Pick Up) not-interchangeable but the Jungle's don't use that anyways. You can see how well the rear Jungle fender flares match the original front ZR2 fender flares on this Sonoma.
Good info, thanks.
All four of mine are in fine physical shape, but the paint on them hasn’t lasted as well as the body, which still looks like new.
Is anyone aware of these jungle flares, since they say they look like the “wicked originals”, are actually painted in the original metallic graphite paint color?
Trying to decide if I’m better off removing mine and having them refinished by a pro (maybe the bumper too at least on the front, given the blending), or buying replacements.
Anyone had any luck finding rear fender flares for the ZR2s? I can find front ones no problem, but no one seems to carry the rears. I already put an ad in the classifieds section, but was hoping someone on this forum would know.
FYI Chevy wants $380 apiece for the rear flares.
camelman
Hi....I can't find a left front well flare for a 2000 ZR2. Know where I can get one?
41 - 47 of 47 Posts
Status
You have insufficient privileges to reply here.
