I got a 1995 S10 4.3L 5 speed. I've already run a bottle of fluid through it, and still aint bled at all. Can barely stop in gear. Does anyone know a special technique to bleeding a slave cylinder? Thanks to anyone that can help.
I would agree. Did you replace your master cyl too? sometimes when those go bad they introduce air into the system with every pump.If you have bled a whole bottle through it then you have a leak somewhere. There is no way you would need to run a whole bottle through it.
the way the master cylinder sits, you have to remove it and tip it up or else you wont get all the air out of the system. it will just trap a big air pocket at the topWait, what? Why do I have to remove everything to bleed it? It was an absolute nightmare getting it all put back together, now I have to take it apart again???
Can a mechanic do this better? I'll have it towed to a place if that's what it will take. I'm sick of working on this damn thing.
I know one thing for sure, I'll never again buy a truck that has a hydraulic clutch. Cable is simple, cable works.
Charles.
