Auto to 5 speed swap questions
1 reading
1.9K views 6 replies 4 participants last post by  Tim99Zr2
So my trans crapped out Sunday night. :( My truck is an 02, 4.3L, 2 wheel drive with about 94k on the clock, and I had it rebuild under warranty at the dealer at 30k. I wanna swap about the 4L for a 5 speed but I have a couple questions.
First being, is the tranny crossmember for an auto and 5 speed the same or will I need a different one?
Second, obviously the 4L is computer controlled shifted, can I leave the computer in and deal with a MIL light, or will I need a computer out of a 5 speed truck?
Third, will the bellhousing bolt up to the 5 speed, or is there some kind of difference between the two?
And forth, the lengths of the trans are the same right? I won't need to get a different drive shaft if I go for a 5 speed will I?
I think that's about it. I'm hoping to get this started later in the week. Any help or information would be greatly appreciated.
Thanks.
#2 ·
i pulled a trans cross member from my 5 speed and a buddy's auto and they were the same.
if you can find someone with a 5 speed truck with all your same options sure can have your comp flashed with that vin#
not sure on the driveshafts.
if i was going to go through that kind of swap. i would do a t56 6 speed instead. the nv3500 that come with the 4.3 trucks are not that great really. :rant:
#4 ·
no you dont have to change the computer. i did this swap. the hardest thing about this swap is putting the clutch pedal in. i bought a 5spd s10 to get the parts from it. mine is 4wd and my lengths were fine. it bolts right up to the 4.3 after you put in a pilot bearing, flywheel, clutch, pressure plate, throwout bearing.
#7 ·
no i didnt plug the speedo in, i think it runs off the tcase anyway. for us 4wd guys. and i have the check engine light, although it could be from many different things. i dunno what codes are thrown
