Just bought a Rockford Fosgate 401s amp and two Kicker Comp speakers. With the rca cables from stereo hooked up to the amp it sounds crappy, doesn't get loud, ect. seems like a weak signal. I then pulled out one of the rear speaker wires and spliced a rca connecter on it, if I plug it all the way in the amp I loose all sound in all speakers, if I plug it in halfway to where the ground is not touching it sounds pretty good but I think it should sound better. So why is the ground wire shorting the system out, and are the rca jacks on the stereo just bad?
