99 2.2 intake removal
4K views 4 replies 3 participants last post by  manbearpig
Need some guidance on taking intake off. Should I disconnect the fuel rail from the line, or will intake angle itself out. Do I have to pull throttle body from intake too. I'm in the middle of removing cylinder head.
#3 ·
Yes, pull the throttle body from the intake. It'll make things a little easier with it out of the way. Personally I just leave the intake attached to the head when I'm pulling the cylinder head. Remove the intake from the cylinder head after the cylinder head is off the engine. Be sure you replace those head bolts too, they can't be reused.
