1st Gen Bigblock Installation
273K views 243 replies 125 participants last post by  bk2life
1st Generation S-10 Big Block Installation
Frame Fabrication
Early style big block Chevrolet motor mounts were used to mount the engine to the cross member. Extensions were welded to the front edge of the cross member and brackets were fabricated for the motor mounts to bolt to.
The front cross member was cut at the back edge approximately 3" and then boxed in. This allowed room for the engine oil pan to clear and so the engine could be mounted low. The right side of the cross member was cut at the starter location allowing enough room to install a GM full size starter although a mini high torque was used.
There were no modifications needed to the frame for the fuel pump to clear.
The frame on the left and right side was cut along the top inside edge and reshaped into a cup shape to give more room for the exhaust pipe to clear.
The front tips of the frame rails where the radiator mounts were cut downward into a U shape, boxed and welded. This allowed room for the height of the radiator. The radiator support mounts on the frame were cut and moved outward to allow room for the width of the radiator.
A stock S-10 two-wheel-drive automatic transmission cross member was used but it was cut, reshaped and welded on the left side to allow the exhaust pipe to pass through it aiding in ground clearance.
Sheet Metal Modification
A section of the firewall was cut out around the steering column and moved 1" toward the driver’s side of the truck. This allowed clearance for the steering column at the head of the engine.
The flange where the transmission tunnel and firewall meet had to be hammered up to give some clearance for the transmission to clear.
Where the right exhaust manifold meets the firewall of the truck, it had to be reshaped at that point to allow room for the studs, flange, and the pipe to clear.
The radiator support was trimmed approximately 2" at the top, in the boxed area, to allow extra room for the height of the radiator.
The 2 supports on each side of the radiator were moved outward, trimmed to fit over part of the headlight bucket area and welded. This allowed room for the width of the radiator.
Since these areas were moved outward, the radiator support mounts on the frame were moved outward also as described in the frame fabrication.
The radiator was moved forward into the condenser location and the condenser located to the outside of the support.
With the relocation of the radiator and condenser, the hood lock support will need to be cut off just below the lock mechanism. Once this is done, another lock support brace will have to be fabricated to clear the condenser and to support the lock. If a support brace is not made, the hood will shake during driving.
The safety catch on the hood lock was also cut because of interference with the condenser. Some type of safety catches needs to be fabricated for the hood lock in case the lock should fail.
The back of the 1984 grille will also need to be trimmed to clear the condenser.
The filler panel between the grille and the bumper will also need to be trimmed to clear the condenser.
(If a later model grille is used there may not be any or very little trimming needed.)
The stock S-10 hood was used. The under hood reinforcement just above the air breather was trimmed to clear the breather. All of the adhesive attachment points were maintained.
The breather used was a dropped base breather allowing more room to help clear the hood. The stock hood insulation was used and flexes enough to close over the breather.
(Hood Insulation) GM # 15659223
Cooling System - A/C
A GM radiator was used from a 1979 Chevrolet van w/small block 400 4 flu.
The radiator filler neck was relocated to the side of the tank instead of the top. Changing the filler neck to a 90-degree bend allowed it to come out past the radiator support thus eliminating cutting a hole in top of the support for the factory filler neck. The radiator shroud is for a 1979 Chevrolet van w/small block 400. It was trimmed 2" and then cut in half horizontally. It was also trimmed near the p/s pulley.
A GM short style aluminum water pump was used. GM # 14058915
An 18" flex fan was used and there is very little room between the fan bolts and radiator. The fan shroud was cut in half and two brackets on each side were made to hold the two halves together. This allows for removal of the top half of the shroud and the removal of the water pump.
The water pump has to be removed with the fan and pulley as a unit. Once the unit is removed it will allow enough room for the radiator to be removed.
(Shroud) GM # 14052540
The thermostat housing was used from an early Chevrolet. The thermostat used is a Robert Shaw 160 degree.
The top and bottom radiator hoses were trimmed to fit on each end.
Radiator hose upper Gates # 20983
Radiator hose lower Gates # 21262
A transmission cooler is mounted between the frame rails in the front just under the radiator shroud.
The A/C compressor is a Sandon 508 134A system. The a/c hoses were custom made using a combination of angled fittings at the top and the factory S-10 fittings at the condenser and drier.
The evaporator and condenser are stock S-10.
The A/C evaporator box was cut and reshaped to allow room for the engine valve cover to be removed.
The A/C condenser was moved to the outside of the radiator support just behind the grille. Two brackets were welded at the bottom of the support to hold the condenser and two straps were made to hold the condenser at the top.
Steering/Pulleys/Brackets
The steering shaft was custom made using 3 universal joints to work around the exhaust manifold and 1 heim joint to support the shaft to the frame. The steering box is the stock S-10 unit.
The shifter is on the column and a B&M shifter cable was used with a custom made bracket that attaches to the end of the column. B&M # 80605 or PA 5020808
The power steering brackets, pump and remote reservoir came from a 1968 SS Chevelle B.B w/short water pump. The P/S pulley is the flat one – GM # 3925537 P.
The P/S lines and line fitting for the back of the pump are from a 1990’s 4.3 S-10. The lines had to be reshaped to fit this application.
The a/c brackets are Alan Grove 118R made for B.B. Chevrolets w/short pump. These use the Sandon 508 compressor.
It came with a double groove pulley and matches with the other pulleys.
The alternator brackets are from a 1968 Chevelle B.B. and the alternator pulley used is a small one.
The water pump pulley is GM # 3905989.
The inner 2 groove crank pulley is GM # 3874418 BS.
The outer 2 groove crank pulley is GM # 5525.
Alternator belt – Gates # 7555 XL
P/S belt – Gates # 7500 XL
A/C belt – Gates # 7603 XL
Front Suspension
The truck uses the V6 springs with a half coil removed and Bell-Tech 2" dropped spindles. There was no modification to the lower control arms. The front sway bar is also stock S-10.
The front brakes are stock S-10 and they seem to work well and so far there have been no problems with stopping and with the added weight it seems to ride good and steer fine.
Exhaust
The exhaust manifolds are stock GM # 3994045 left
GM# 3989310 Right
The exhaust on the left manifold exits at the back and turns in close to the oil pan.
The exhaust on the right side exits out at the back toward the firewall of the truck.
The firewall of the truck had to be cut, reshaped and welded at that point to allow room for the studs, flange, and the pipe to clear.
The right upper control arm was cut, reshaped and welded to allow more clearance for the exhaust manifold.
The exhaust pipe that was used is 2 ½" aluminized. Clearance at the oil filter was a little tight since more ground clearance was needed because of the truck being lowered.
The mufflers that were used are Flowmaster 40 series # 942542.
The mufflers were placed under the cab and above the frame line, and there is clearance between the cab and the top of the muffler.
If the frame were stock in the rear of the truck it would be better to place the mufflers past the cab to cut down on interior noise.
Since this is a Pro Street truck, the narrow frame limits the placement of the tailpipes, so they were placed high by the frame then turned down in front of the rear tire just showing very little of a chrome tip.
This sounds like a lot to deal with but a very good muffler man makes all the difference.
Just Thoughts of What I Did
Everyone always ask, "How fast is it"? For me it wasn’t about how fast it is, it’s the fun of drivability. The engine is not that radical. I used a 454 engine and a 350 automatic transmission. When I was building the truck I wanted to be able to cruise around town and travel to some shows out of town without the fear of breaking down. I looked for all stock type parts that I could, like belts and hoses incase something did go wrong replacements could be found at just about any local parts store.
As far as fast, a good built small block could surely out run this truck. Having the Big Block in it is fun for me when we go to a cruise-in or car show because most people don’t believe that there is a 454 in it. They think that everything in the truck has to be gutted and cut up to get the B.B. installed. I like cruising out of town with the a/c on, cruise set and listening to tunes. So far the truck has a little over 6,000 miles on it and everything seems to be doing well. I’ve driven it through the mountains of TN and to the coast of SC.
The BIG question that everyone wants to know is "does it run hot"? It depends on if you are in stop and go traffic. In town on a mild day it might run 180-195. On a hot day driving around town it will run 200-210 with the a/c on. When we have been traveling on the highway with the a/c on at 70 mph it would run about 190-200 depending on the heat.
I was asked the other day what would you do differently? The first thing is I would have had an aluminum radiator in it. I believe that it could possibly cut the temp by 5-15 degrees. When I built the truck I really wanted to keep the stock hood on it with the Big Block so that it would make you wonder what motor might be in it. I think that might have bitten me in the butt.
There is very little intake area at the front of the radiator support although I did cut the area out to match the cooling area of the radiator. Having the bumper and the bumper filler panel there blocking some of the airflow and having a closed hood with not a lot of area to blow the hot air out it seems to hold a lot of heat in the engine compartment. Keep in mind to how low the truck is to the ground and how much heat is coming up from the road also. I think with a cowl induction hood on it that is open at the back it might also help lower the temperature.
The second thing I would have done differently is not have did the Pro-Street thing. It’s cool to see the fat tires under it and sweet to roast them but it’s not easy to drive in the rain. I had the Mickey Thompsons on it before they come out with the Hoosier Radials and at about $300 a tire I’ll have to wear these out first before they get changed. A good 10" street tire would have looked good and been easier to handle in wet conditions plus they would be a lot cheaper to replace.
There was a good bit of cutting and welding involved and this is not something you can do in the driveway but mine was done in a single car block-building garage. I’m a Collision Repair Tech. and have some mechanical and MIG welding experience although I’m not a mechanic or certified welder. I don’t want people to read this and think that I think I know all there is to know about installing a Big Block in an S-10. I read an article years ago on a BB S-10 and liked it and wanted to do it. I also had a friend that did it before I did and gave me a lot of help with issues I had. "He’s my hero". That’s for you Eddie!
I’m sure there was some things I may have left out in the description of the install if so e-mail me and I will try to help. I like seeing what everyone is building.
See Ya, Tim
#196 ·
thanks a lot for all this info,so informative, I would like to put a BB in my 85 s15 at some point. I'm restoring it from the frame up. Did you strengthen any part of the frame behind the cab? I figured while the frame is sitting here, I'd put some heavy duty cross members in so I don't snap or twist the hell out of the frame my first time out, before I send it out to be sandblasted and powder coated. thanks in advance
#197 ·
Sorry for the late reply.
Thanks, the rear of the frame has been cut off and a new one fabbed to be narrow and higher than stock. The rails were built using 2x4 steel with 2x2 crossmembers.
I used 3x5 steel to connect the stock rails together before cutting the rear half off, (that way it kept everthing aligned) , where I had cut the old rear half off, attached the new rear sub frame to it, made some gussets where the 3x5 and 2x4 meet, and where the 3x5 and stock rails meet, once everything was lined up I cut the middle of the 3x5 out (where the drive shaft would be) then capped the open ends of the 3x5 on the left and right (cleaned it up). I used the stock S-10 front spring mounts, I had to move them up on the new frame some, then drilled the new frame, tapped the holes, bolted them, and tacked them for safety measures. On the rear I used new GM sleeve bushings, used a hole saw the right size, hammered them in and tacked welded them in. The rear springs are stock S-10 (and shackles) with the load leaf removed.
Maybe a little more info than you wanted but I have alot of people wanting to know what was done to the rear so this might help some else too.
#200 ·
oh I bet it would considering I have mud under my hood right now. and love playing in the mud.
#211 ·
first off VERY nice job on your s10. you did it for the same reasons im thinking about taking on the same kind of project, to DRIVE it. today i acquired an old rocket 455, mildly built along with a TH400 trans which is built for abuse. i plan on doing a similiar build as you (originally started out as wanting to do a 383 but i just got this motor/trans for next to nothing) with the intention of just driving it,occasionally take it to work on a friday and maybe out on a sunday type deal. i do not intend on racing this thing but it will go to the track at least once just to see the time slips. im not looking to build a show truck either, i want that extra oomph for when i need it, and i absolutely love first gen s10's, i honestly dont see myself driving anything else, ever. my main question is what kinda man hours did it take to do your BB swap? approximation is fine. and what kinda time do you think would be involved in just doing the swap without making it show-quality? still unsure of what i want to do about the rearend. if there is a ridiculous amount of time in it i might be lookin to do the SB instead to have ready for cruising season of 2012. i thank you in advance and once again GREAT job on your daily driver :)
#212 ·
I don't know how often Mr. Lambert checks this thread, since it is older. I have a Big Block 1st gen (92) myself, and 2 Small Block 1st Gens (85 & 91). I would honestly say that it not that much more work than doing a small block. Now with that said, if you want to suprise people, or go for a "sleeper" look, and you want to do this under a stock hood, you will have to notch the front crossmember. You can cut it in 20 minutes, but you will need welding skills to make the patch panels. I made my templates from cardboard, then cut and fit, before welding. If you want, or like a hood scoop, then you dont neccesarily need to notch the crossmember. I have done this both ways. Now, either way you decide to mount the engine, you will have exhaust issues, ESPECIALLY with the wider Olds block. This will be your biggest challenge. No body makes headers for a Olds/S10 swap. So again you will need welding skills in order to make your own. There are a few companies that offer universal weld-up header kits to design your own. This will consist of pre-fabbed flanges, and "u" & "j" bends. No matter how you decide to mount the engine...no matter how you decide to exhaust the engine, you will need steering shaft modifications. This is not so tough, but you will need welding skills again. You will more than likely have to move the column over an inch???( 3 bolts on the firewall) and make you own shaft, more than likely using a ujoint or two, and possibly a steering shaft support (heim joint). I did not have to hack my firewall. Depending on valvecover style, you may/may not have to remove the brake booster. These are you biggest challenges with installing a Big Block. Now with all that said...I've never seen a Big Block Olds swapped into a 1st gen S10. Use a motor plate to mount. Buy a weld up header kit, and buy a Flaming river steering shaft, ujoint(s),and support. Now I say go for it!! And swap a 1st gen Bravada grill, bumper cover, tail lights, steering wheel, center console, etc. I think I just described my next project...LOL!!! You better get to work, because 2012 cruise season is just around the corner!! James-
#213 ·
James, that is a perfect statement for anyone one wanting to do a BB swap. Thanks for answer that post cause I haven't been on here in awhile.
Its funny reading your reply because what you said I remember doing!
I get e-mails sometimes with questions about how to do it. Its tough to answer, peoples skills are different, and tools equipment that they have available are different.
If I were to do it again I could do it quicker for sure, there was alot of trial and error when I was getting it together. There was no plans to go by, but I did find a magazine article with an S-10 BB that was a street truck and looked basically stock.
I do love this truck, and I have had it since it was new. Its been through its 2.8 V6 at 92,000, then ran a 350 small block for awhile. I robbed the 350 out of it to go into an S-10 extra cab long bed I built. And then finally did the BB swap.
I think I have said this before in this thread, if I were to do anything different it would be to NOT tub it and I WOULD do an overdrive trans. It doesn't need it now with the gear I have but it would have been nice.
#214 ·
DAMN! DAMN! DAMN! That is a bad ass truck homie. I'm new to this website and the pics and ideas that I get from here are amazing. They need to have a magazine just for s10 like the do camaros and mustangs. I didn't realize that the s10 community was so big. I have a 89 gmc s15 and one look at you truck is exactly what i want my truck to look like but a different color. Two thumbs up and some toe's bro. 1-10 your truck broke the scale. Heavy and clean work. Keep the truck in the family it will be seen one day...
#215 ·
This kind of answers my question I always ask myself. Do I wanna put my 502 in an S10? My reasoning isn't for a street cruiser but more for a vehicle that can be driven to Etown to make some runs and then drive home. It will also be boosted via a large 88mm Turbocharger.
However with how lazy I am I think I'll stick with the SBC and look for a G body to throw the 02' in?
#218 ·
mcarlson - heres what's required to get your BBC to sit low in the engine bay. It's (3) cuts with a sawzall, then cardboard templates, cut your filler panels with 3/16" flat plate, and weld them in. You will need to use a "car" oil pan, more commonly refererred to as a Chevelle oil pan. I used Jegs brand "universal" aluminum engine plates, as my motor mounts, and trimmed them to fit my frame rails.
And then fab you some brackets and weld them to the frame. Good luck with your project! James-
#221 ·
That is what I was looking for.
I am selling all of my 4x4 stuff and going to buy my 10 yr old an old S10 and drop a 454 in it for his first vehicle.
Stock and low to look just like the OPs.
Thanks for the pics.
Oh, no tubbed either for us, maybe a mini-tub, but no nothing narrowed until he learns to fab and weld.:D
#220 ·
That is very well built. Don't be shy..I need to see more of that truck. How bout some specs??
Here's a couple more pics of my 1992 drag truck. It's 800ish hp 468" by Nickens, fully built Glide w/ 5500 Trans Specialties spagless converter, fully built 8.8 rear w/ 5.13's It runs easy low 6's on the motor. Was going to sell, but I'm thinking of keeping it for a couple more years until it's emissions exempt, putting the headlights back in, and ProStreetin it. We'll see...
Corvette radiator installed in the forward position, Aerospace water pump, AFR 345's, CompCams .748, AFR stud girdle, Edelbrock Victor, Dominator, Callies/JE rotating assembly, Stahl headers, etc..
It's dirty, but cleans up nice.
See ya... James-
Reactions: fattboyzz65
#223 ·
Mcarlson, I haven't been on here for awhile, sorry I missed your question.
I did my crossmember simular as above, but I left the very bottom of the crossmember in tack. I did have to shorten the distance from front to rear width of the crossmember also so there would be room for the oil pan to sit into.
My oil pan sits just above the bottom plate, plus it keeps the oil pan from getting smacked on the road or something in the road. My truck is really low and it was a concern for me since it is a street truck and not really built for the track.
Sorry I don't have any pics of what I did.
