I finally got some work done on the truck. The cage is a Jegester kit that I bent to get the bars where I wanted them. When I bought the truck from my son it came with a 8.5" rear from s blazer. I narrowed it welded the tubes to the center and installed the ford ends. Moser limits the "stick out" of their axles so the backing plates needed to be clearenced and attached to the back side of the housing ends. It has a 3.70 gear and a spool and 33 spline axles. Also I mounted with with Smith Racecraft bars. I bought a 02 LQ9 from a Caddy and used Trans Dapt mounts. I set it as low and as far bak as possible. The trans is a 1000hp 4L80E with a brake from Extreme Automatics. I got lucky and the drive shaft from the GN was the right length. I made some turbo headers from stainless but weld fittings. The turbos are Limit Engineering LT70 with a Qtrim exhaust wheel. The down pipes are 3" stainless and had to be run under the K member. The driver side crosses over to the passenger side and merge into a single stainless 4" pipe with a Magnaflow muffler. I'm still waiting for some 4" 90's to finish the tail pipe. It will exit in the stock location. I still have to finish the waste gate plumbing ,they will tie into the down pipes and build the cold side of the turbos. For now there will be no innercooler. I plan on running it on E85. We'll see how much boost I can run without one. The engine will get a 4" crank cnc ported L92 heads. With the Holley intake the stock hood is about an inch from closing time for a cowl hood. Once the turbo plumbing is done the engine will get pulled and built. I still have to build the fuel system cooling system and do the eletronics. I plan on using a stock ECM.
