02 S10 ZR2 - no door locks or mirrors
3.7K views 17 replies 5 participants last post by  Joshyboy2002
Hi, I was doing some testing today on my power mirrors(still haven’t found the problem) and the door locks stopped working. I checked the fuses and none are burnt and the relay is still working. Are these two problems linked together in anyway? Any insight into the problem would be greatly appreciated
#6 ·
If the door locks worked prior to your messing around, you obviously wiggled something you should not have.
Have you tried the other door switch? Do the locks not lock or if locked do they not unlock? Or neither? What relay did you test? The power locks have 3 relays in the body relay block up behind the headlight switch. You have to access it from underneath.
BTW mir/lks fuse under the hood is for both locks and mirrors. Only trucks that came originally from the factory with power mirrors and locks have this fuse. Depending on year and model it's either 3A or 5A.
#8 · (Edited)
Go through where you were messing with the wiring. Something had to have gotten unplugged or broken when you were in there. Make sure everything is plugged in good, something coulda got bumped. Also make sure that, if there are any spots that are crimped together (even the connectors), the wire is still connected good. They can loosen over time.
Edit: Is there a way to test door locks? If so, try seeing if the door locks are still good. I don't think they would of just quit like that though.
Also, do the door locks and power mirrors not work on both sides?
#11 ·
You say you tested all relays, did you check the one in the body relay block? Did you check the under hood fuse I showed above?
This will help you find and diagnose the BRB (see #7 in the schematic)
#13 ·
To add to ODS link regarding Body Relay Block (also known as Body Bussed Electrical Center), this link shows how to remove it without removing the dash:
