OK, so I was up until 1:30 am yesterday and I completed the entire job in one go. All I did was replace the intake guide seals and the stem seals... I left the exhaust seals alone as GM had put in SBC viton guide seals on all the exhaust valves for warrenty work when the motor was new.
I found only 1 out of 6 seals that was good, 4 out of 6 were leaking and installed incorrectly from factory, and 1 seal was completely exploded into little bits!
It definitely burns less blue, and the pre-detonation is gone, but it still smokes a bit after idling for a while and then reving it. Should I give it some time to seat or something?? Maybe its really gummed up?? It burned an entire litre of oil last week!
