1997 RWD 4.3 x vin manual LS extended cab. I’ve looked everywhere.
I agree, find a local shop to make you one. I made my own and I wish I had paid someone to do it instead. And definitely go larger on the pipe size: at least 2", but up to 2.5" should work well.Go down the street to the exhaust shop. They can fix you up and use larger pipe.
FYI, I was quoted $200 for a reputable shop to do mine back in 2008. I decided to buy $20 in exhaust pipe and do the job myself, as figured I could learn how to weld and save money in the process. I ended up spending more than $200 for 2 different shops to repair my inexperienced results (the original guy refused to touch my truck after I tried to make my own Y pipe, understandably). In my opinion you're making a good choice.Have an appointment for Monday to have one made. What’s 300 more into the money pit? Wife despises my truck and has no idea why I spend time making it nice. Speaking of anyone know a good place to find the door panels. That is one of the last things I need to finish my interior.
Mine has the flat section on the bottom.FYI, I was quoted $200 for a reputable shop to do mine back in 2008. I decided to buy $20 in exhaust pipe and do the job myself, as figured I could learn how to weld and save money in the process. I ended up spending more than $200 for 2 different shops to repair my inexperienced results (the original guy refused to touch my truck after I tried to make my own Y pipe, understandably). In my opinion you're making a good choice.
Just out of curiosity, does your factory 1997 Y pipe have the crushed section under the transmission like my 2003 used to?
