Ok i went to autozone to have them check my battery..they came out did a check on it ..it came up loose cables check for errosion...wtf my cables arent loose an there aint no errosion...so i was like ok whatever..i go to leave start my truck up the gauge cluster lights turn on...the oil an volt gauge turn on...my my rpm an spedo gas...an whatever else there is wouldnt turn on also under the rpm gauge were it has park drive an all that crap ..to show what gear your in was off an same under the speedo...so im like wtf an i back out then put it in drive....my truck is an automatic also ...so i put it in drive an for those of you that have an auto if like lets say you put in the 3rd gear an start off..it kind of lags? like i will give it gas an it will barley get going...but its in overdrive an it wont go into a passing gear it wont shift to get to a lower rpm or nothing...what the hell happened? did he **** something up when checking my battery?..the only fuses i have found that are blown aare the heat an ac fuse an the gauge cluster fuse.....does anyone know what could have happened? what the hell could this be...why would my tranny act weird an keep blowing those to fuses?
