EyePoppin said:
just pull it up on the trailer, air it out, then use ratchet straps to hold it down, go up and over the front frame horns, then around the pig in the back.
i have over 10 years of experience in towing every thing from sky rider 4x4 to the commercial lawn mowers and here are a few good ideas to follow.
1. never hook to the suspension, the components may get pulled out of alignment, hook to the frame. also on a rough road the truck is going to jump around which can cause the trailer to sway.
2. air the truck down on either wood 4x4s or sand bags (i prefer the 4x's), i sean a guy loose his truck due to it dropping while being trailered.
3.use the straps over the chains, 4 are better than 2. if using chains try to use 1 binder if possible and use a rag or a piece of wire to keep it shut.
4. don't worry about the ball joints, if you brake them they were bad to begin with or you chained to the a arms.
5.after about 25 miles check to make sure it is still tight and just to be on the safe side check it at every gas stop to be on the safe side along with the trailer tires(not low or flat like i found out last weekend)
6. use good common seance.
i have trailered my body dropped blazer about 10,000 miles in the last 7 years with no problems. i also have never broken a ball joint on it either. i wish you good luck with the drive and congrats on graduation.
