developed
· ol' bodybuilder
Discussion starter · #1 ·
I have a 97 S-10, 2.2L, 5 sp, 4:10 rear end, 225/70 15's and just figured out I've got a problem with my Stock tach's accuracy - BIG TIME. I replace the No-Tach cluster that came in it with one I got online from a salvage yard that's suppose to be from same year, same engine/trans. It had MORE bells and whistles than the one I replaced and "everything" works. Tach tops out at 6000, redline begins at 5000 and Lite-Red at 4500 - does this sound correct?
At 65 MPH in 5th gear the tach indicates only 1950 RPM! I just got the trans 5th gear ratio and went to several online calculators and they all said it sould be ~2700 RPM!!
I tried to do a search a see if anyone else has come across this to no avail. I did find a post where people knew about capacitor size to replace on the cluster ciruit board to correct it. They talked about some member having a pic but not saying where it was located. The thread was about 6 and 8 cylinders, not 4's. :(
Does it sound like they sold me a clust that was for a 4.3? Does anyone know about replacing this capacitor to correct this along with pic/diagram? I may be able to figure it out from the Chilton's but not sure how detailed the wiring diagram is for the cluster.
thnx
developed
yup, you got a 4.3 cluster.
Discussion starter · #3 ·
WTF?!?!
Can anyone tell me if the 2.2 and 4.3 tachs have the same range? If not, what's the specs on the 2.2 or if ya have a pic would work too. I'm guessing the 2.2 is like a 6000 or 7000 RPM tach?
The reason I'd like to knnow is so when I get another, I don't get screwed again.
2.2's have a 7k tach, 4.3's have a 6k tach with different spacing between numbers. it's really not an issue unless you keep you truck at redline and don't expect it to last long.
don't know. i have a 6k white gauge in truck and it's a 4cyl. i'm not worried about it, the tach is just extra the speedo is what really counts and it's the same for both.
