I guess if I would google it...
Removal & Installation
2-Wheel Drive - 2.2L Engine
Remove or disconnect the following:
Negative battery cable Front exhaust pipe, if necessary for access Starter heat shield, if equipped Brace rod from the front of the engine and the bell housing Drivers side wheel to access the starter motor wires and the starter motor attaching bracket-to-engine bolt through the opening in the wheel well Wires from the starter solenoid Attaching bracket-to-engine mount bolt Starter-to-engine block bolts. When removing the last bolt, be sure to support the starter to keep it from falling and possibly injuring you. Starter and shims (if equipped) from the vehicle Bracket from the starter assembly, if equipped
Fig. Starter motor and related components - 2.2L engine
To install:
Install or connect the following:
Bracket to the starter, if removed. Tighten the bracket nuts to 97 inch lbs. (11 Nm). Starter and shims (if equipped) into position in the vehicle and thread one of the retaining bolts to hold it in position. Bracket-to-engine mount bolt (loosely), if equipped Starter mounting bolt, then tighten all mounting fasteners to 32 ft. lbs. (43 Nm) Wiring to the solenoid Brace rod and tighten the retainers Front exhaust pipe and tighten the fasteners, if removed Starter heat shield, if equipped Driver-s side wheel, if removed Negative battery cable
