I am about to lose my mind!!! I have a 2002 Chevrolet Blazer that I have been trying to figure out a random misfire code (which does not let the converter lock up). What has me really confused is with the coolant temperature sensor unplugged it works perfect (no code and converter locks up every time). I do not know if this will cause other problems, but with the scanner live data shows -37 deg with sensor unplugged. I do not like driving with no temp gauge. I have replaced a lot of parts and now wondering if its the ECM. If anyone has had or heard of something like this, I would really appreciate some help to finally fix it. Here is a list of some of parts that are new:
Mass Air Flow (MAF) Sensor
Fuel Injector Conversion Kit to MFI
Fuel Pressure Regulator
Idle Air Control (IAC) Valve
Remanufactured Engine
Spark Plugs & Wires
Crankshaft Position Sensor
Camshaft Position Sensor
Throttle Position Sensor (TPS)
Distributor
Distributor Cap & Rotor
Fuel Pump
Spark Plugs & Wires
Distributor
Fuel Pump
