So I have a 2002 4.3l 4x4 s-10 an the radiator dose not pull water from the plastic reservoir. Is that supposed to be just for overflow or what? At first that’s what I was thinking but then it dawned on me that if it was just for overflow then why do you have to add water to it to keep it up to the line on the side? Makes no sense to me. Then I see there is only two hoses. One just goes straight down for overflow an the other goes into the radiator right at the neck where cap screws on. So if radiator is supposed to pull water out when needed then how dose that work bc it seems it would have to create a vacuum to do so an can’t do that with a open overflow hose hanging off tank. Makes no sense at all to me. Somebody please help an explain if ya can. Thanks in advance
