21 - 40 of 91 Posts
Discussion starter · #21 ·
What is the flat plate for and the notch from who? I'm almost ready to place my order. Just have to figure out about rims. Tomorrow she gets on the lift and I get to see the nightmare. Thanks guys about all the info. As soon as she gets the drop fixed I can start planing the metal work.
I'd get helper bags.
What flat plate?
jagsthatrun.com for your drop blocks and set back plates.
And to put the notch I have dehump it correct. Might as well get it out of the way right?
you can dehump the LCA's. Are you talking about removing the bracket on the rear part of the frame?
Sorry guys . What back plates for ?
I have to remove the bumpstop in the rear to install
The bolt on notch any ways correct
Set back plates move the axle back approx 1/2" to give the drive shaft room to move.
I'm not sure on the notch, but I'd say yes.
Sent from AutoGuide.com Free App
Ok guys here it is . 4 3/4 blocks. Everything should go correct? Any way to tell if these are drop spindles .check out the missing but nut in rear shock
Looks like the previous owner welded two blocks together...sketchy.
21 - 40 of 91 Posts
