i am going to buy lowering blocks and do ineed to by a kit or can i just by the blocks i am ethier getting 1in or 2in blocks
You'll spend more too if you try to buy the blocks and then the bolts. You can usually pick up blocks and bolts for $20 to $30 dollars.grndscrpr03 said::werd: If you don't buy the kit, then you will have to find somewhere to buy just the ubolts. With the blocks, the stock ubolts are too short, so longer ones are needed and they are included with the block kits.
2000sonomadriver said:
Reznor said:Is the best way to get blocks for back and coils for front? I'm new at this stuff, i've been running off-roaders for years.
http://store.summitracing.com/defau...+4294925022+4294844590+4294908400+4294907040+4294905283+4294905933&autoview=sku
Note: For 1997-2004 GM S-10/S-15 you will need a block plate that can be
added for an additional $15
the Chad said:saw this in the ebay auction. what the hell is it?
Are they included in that kit? There's 2 sets of shocks.grndscrpr03 said:but you will also need drop shocks for the front.
Reznor said:Are they included in that kit? There's 2 sets of shocks.
Reznor said:I probably will. My truck's stock, and i checked the rear shocks. They need replacing.
