I have a 04 5.3 in my 98 s10.Heads are milled .010 I was thinking about getting a set of LS6 heads.Would it be worth swapping heads,or just keep my stock 706's?
Mike
Mike
Yes, they are the exact same heads, no difference.Would the newer 5.3 heads(243/799)be as good as the LS6 heads?
Unless for some reason a user is displacement limited (racing class, aluminum block ect) 4.8L pistons are a bad investment. If you're getting new pistons solely for higher compression, bore the 5.3L block over to 5.7L and use flat top LS1 pistons which are far more common for less cost. In the same vehicle, gas mileage will virtually be unchanged between the two motors but you'll have about 10% more torque, everywhere....or you can put in some 4.8 pistons and not need to mill them.
