How to replace computer?
4.8K views 53 replies 7 participants last post by  Wheatfree
I have a 1987 s10 2.5 4cyl and I’m picking up a new computer in the morning, I know how to replace the computer but Im unsure of if I will have to program the computer or if there’s an easier way? I’ve been told the chip inside can swapped (or something similar?) any help is appreciated
#11 ·
I always disconnect the battery, I’ve seen people cost themselves money just trying to do simple cheap stuff. I haven’t checked both ends of every ignition system wire because I couldn’t find any diagrams for the truck and wasn’t sure where everything went. I have checked the battery and the connectors for the distributor and ignition coil and a few others that I can’t remember right now.
#10 ·
I actually haven’t, somehow that slipped my mind and I never even thought of it. I will check that today and I plan on getting my old computer and taking it with me so I can see if the numbers match, I ordered from Oreillys and they never mentioned having more than one variety so idk.
#12 ·
I forgot to mention but my fuel injector is not spraying either and I was told that the computer controls the spark and fuel injector which is another reason I was leaning towards replacing the ecm. The fuel injector is clean and has voltage and I am getting fuel to the injector so I know fuel pump is good. Does that sound like a bad ecm at all?
#27 ·
The prom has to stay with the truck. It contains all the info the ECM needs for your particular engine, transmission, etc.
ECM's rarely fail. Not saying it can't be, but I'd bet 90% of the ones replaced didn't need to be. Something else was the problem. If the numbers don't match at O'reillys don't be too concerned as long as the electrical connectors are exactly the same and the Prom will switch. In that era GM used different part numbers on ECMs that were basically the same. Usually, if a newer faster or better computer was introduced during a model year they would just change to it. In later years they only did it when the MY changed. And then they changed almost every year.
#31 ·
Not sure if the 2.5 back then had a crank sensor. If it has one was the crank sensor checked at all? no RPM signal results in no fuel/no spark.
#43 ·
If you don't have a check engine light with key on engine off, you might not have proper power or ground to the ecm.
#46 ·
Would you know where I could find one of those? I’ve looked for diagrams and can’t find anything reliable. I have a ground from firewall to the rear of the engine and I have the negative battery cable to block and a ground from the negative cable to the inner passenger fender I think that’s all of my grounds
#52 ·
gotta have the chip set!!! memcal is where all the data is loaded to in those old ECM's. you need a scan tool to see if you have a crank signal.
