How To Install a Remote Start and Alarm
By MeltingPlastic
Unfortunately there are no pictures at this time. Next time I do an install on an s-10 I will take pictures. Unless someone else wants to take pictures when they do it.
NOTE: I’m giving you this information free of charge. I’m not responsible with what you do with it. You can do a lot of damage to your car/truck’s electrical system by messing up while installing remote starts and alarms. PLEASE make sure you understand each step of what you are doing before you attempt this. If you are the least bit unsure, please have a professional do the installation.
So you’ve decided you don’t want to spend the money at a retail store or install shop on an alarm and bought one off eBay. Problem is now who’s going to install it? Sure Tom Dick and Harry install them so why can’t you. Before I go into any sort of information on remote starts here is some background information you will need.
Tools
Digital Multi-Meter (DMM) - THIS IS THE MOST IMPORTANT TOOL!!! I REPEAT! IF YOU DON’T HAVE ONE OR DON’T KNOW HOW TO USE ONE LET A PROFESSIONAL DO THIS INSTALL. Sure you can get any wiring colors you need, but guess what when your in a harness with 20+ wires, There are some wires that are the same or look the same. You need this to test the voltage of the wires and confirm you are getting the correct voltage. They are relatively cheap and will save you headaches and a lot of money incase you tap the wrong wire.
Wire Strippers These are your best friend when it comes to remote starts. The style in the link below allows you to strip open the wire yet not cut it, making it great for getting your wire prepped for connections
http://www.cardomain.com/item/SOU18950
Pick Tool This is another tool that you shouldn’t be doing your remote starts without. Once you’ve stripped your wire back to make your connection, use the pick tool to poke a hole in the wiring and spread it open. You can then insert the wire from the remote start system into the hole and twist it around to make a tight connection.
3M Super 33 Electrical Tape This is the only electrical tape I will ever use when it comes to doing installs. This stuff is durable and sticky as hell!
Zip Ties After making a connection to a wire I like to run the connected wire parallel with the factory wire and zip-tie them together. That way, if the wire ever gets tugged on, the force is on the zip-tie not at the connection joint allow for a cleaner better install
Unibit This isn’t a cheap tool at all and isn’t necessarily needed, but if u plan on doing a lot of installs, pick one up. It makes it easier to drill through the firewall to the size hole you need
http://www.irwin.com/irwin/consumer...ml?brand=Unibit
Right Angle Drill Another tool that is great for when you are doing these installs a lot. It allows you to get into places on the firewall that stardard drills don’t allow you to.
Prepping Your Wires
This is the most important part if you would like a clean, factory looking install. Remember, an alarm is only as good as its installation. What I like to do is sit at a bench with both the wiring diagram to the alarm and to the car. Take your time and separate each wire by destination. Put all the wires going to the BCM together, all the wires going to the ignition harness together, etc. once you have all of the wires separated by their locations, clip off the wires you are not going to be using for the install(some cars don’t need the factory alarm disarm/arm or other such wires) With DEI alarms, I like to use my pick tool and pop the wires I’m not using completely out of the harness. The extra channel wires I’ll keep in the harness but cut them short so that they are not in the way. Now, with the wires you cut short tape up the ends to terminate them and begin taping your other wires. Make sure you cover each group completely with electrical tape. This will deter the thief from knowing which wire is what if done correctly and also allows you to route the wires easier because you only have to worry about 3 or 4 looms instead of about 30 wires.
Mounting the brain
This is the most crucial part of the install. Not only must the brain be hidden but if you place your brain first, your install will be cleaner because you can cut your looms to as long as they have to be and not have to worry about all the excess. On the 2nd gen s-series I like to place my brains (NOTE: I mainly use DEI alarms/remote starts which have small brains which allow for ease of hiding, if you have a unit with a much larger brain like Auto Page, it might take a while to find where you can mount it) above the accelerator pedal by the steering column. There’s a piece of metal that the brain can be zip tied to very nicely and does not get in the way of the pedal if done correctly. Many installers will screw the brain into the firewall somewhere. Its all personal preference and after a while of installing you’ll find places for each car where a brain can go.
Running the Wires
Like I said before, you want the install to look as factory as possible. It’s suggested to run the wires along side factory wires. This not only makes it clean and compact but allows for easier routing of the wires. I HIGHLY Suggest this method.
The Remote Start Wires
Starter: This wire only shows 12 volts when you go to crank the car. To test this, put your DMM on DC, ground the black probe, put the red probe into the wire were you stripped and crack the car. It will she 0 volts on rest, 12 while cranking ( your DMM may never get to 12 but to like 8-10 depending upon how fast it updates its values) and the drop back to 0 when you stop cranking.
Ignition wires: These wires show 12volts when the key is in the ignition position, KEEP 12 volts throughout the crank and keep 12 volts after the crank. They will show 0 volts when you put the key into accessory.
Accessory Wires: These wires will show 12volts when the key is in accessory. When you crank the car, they will drop their voltage (ever notice how your radio shuts off when you crank you car?)
Keysense Wires: These wires are different for every car. Most of the time they will show a ground when the key is in the ignition
Tachometer Wire: This wire is an AC wire, so you must set your meter to AC. This measures the RPMs of your engine, the car should idle at about 1.2-1.4 V AC and go up to about 3 v when you rev the engine. This wire is usually located under the hood of the car by the computer. You are either going to have to drill a hole in your firewall and use a rubber grommet and run the wires through there or find a factory grommet that you can get the wires through.
The Alarm Wires
Horn Trigger: This wire is a negative trigger. That means, it will show 12 volts at rest and when you press in the horn it will go to 0 volts(or ground).
Door Trigger: Each car is different. Some of positive some have negative. S10s have Negative. That means, when your door is open, it will show ground on that wire
Dome Supervision: This wire allows for your dome light to go on when you press unlock. In s10s you are told to use a door trigger. This is because on S10s, the dome light goes on when you pull on the door handle even when its locked.
Factory Alarm Arm/Disarm On S10s, you only have to deal with the factory alarm disarm wire because the factory alarm arms when you lock the car. What this wire does is when a negative pulse is sent to it, turns off your factory alarm (yes your truck comes with one from the factory but all it does it honk the horn and flash the lights)
Parking Lights These are the lights that flash on your truck when you lock and unlock the car. They are positively triggered lights. (When you put 12volts to the line they turn on) This wire will test for 12volts when you put your headlight switch the parking light option (the one before the lowbeams) *NOTE* Many cheaper alarms only come with a negative parking light wire. S10s have both pos and negative. If you prefer to use the positive wire and only have the negative wire, you must use a relay to convert the polarity of the wire!
Lock/Unlock These are the wires that are used to lock and unlock your truck. They are a positive pulse to the wire. They meter out to 12v when you push the lock or unlock buttons. Again, many alarms only come with negative lock and unlock triggers. You will need to use 2 relays to convert the negative triggers to positive triggers for both the lock and unlock wire on the alarm.
