Thought I would post this little episode on a timing chain malfunction.
1250 miles ago I went through the whole engine, including a new Cloyes cam chain tensioner. I didn't replace the chain and gears, as they looked pretty good. Put the little plug thing in with the oil hole in it that came with the tensioner.
It ran real nice, but always had timing chain noise. It sounded like a little baby diesel. The other morning it wouldn't accelerate well, then made some noise and died.
Upon teardown, I found the nylon pad on the back side of the tenioner had come apart, and pieces of the nylon had imbeded into the chain. Also the spring on the tensioner had lost it's tension.
It had jumped a total of 4 teeth. I had pulled the sparked plugs and turned the engine over with a wrench to check for tight spots (bent valves).
I didn't like how it felt so I went ahead and pulled the cylinder head and removed each valve spring ot check the valves, but none were bent. I havn't checked the pushrods yet.
I'm not real comfortable with the new tensioner I got, but will be going back to the same parts store for another one as I feel that as many that have been sold, I'll be alright the second time. I'll be sure to clue in the store on what happend! I'll buy a complete timing set this time as I'll take no chances this time.
If anyone has ideas on this deal feel free to chime in. I just offer this for info mostly.
thanks
thanks
