Bagg Back Or Front First?
Help With Bagg Setup
1.3K views 21 replies 14 participants last post by  98 step side
Ok I wanted some second advice on this all before I went and ordered everything. I want to bagg my 94 2.2 dime with just fb right now. Nothing too expensive just a good set-up. Im either bagginf front now back later or back now front later? I was thinking 2500 baggs, 2 3/8 dump, 2 1/2 fills, 1/2 line, Jasons cups, shock relocaters, hardbody shocks, single 5 gallon with 450 or if I do the back 2600 baggs,1/2 line, 1 3/8 dump, 1 1/2 fill(or 3/8 fill, 1/2 dump where back lighter? heard ppl doin that), 5 gallon and 450, raised gas tank, over axle bridge setup, 3 link? Thanks for any input....
#6 ·
lowridinkid said:
Alright thanks so I'll bag the front but does this sound like a good front setup for daily driver 2500 baggs, 2 3/8 dump, 2 1/2 fills, 1/2 line, Jasons cups, shock relocaters, hardbody shocks, single 5 gallon with 450
thats exactly what ive ordered minus the shock relo's
just waitin for the big shippment!
#10 ·
and I wouldn't use 2500 lb bags. Upgrade to the larger it will ride hella smoother I promise
#13 ·
sadexcuse4s10 said:
if you have a 4 banger, the 2500 bags will be fine
that's what i have, 2b6 up front with hardbody shocks and the ride is great
I swear I hated my ride with them. But course I couldn't run shocks cause of dem wheels, so maybe that was why. but ever since devin switched them out I'm much happier
#14 ·
Im gonna get spindles later down the road, had to put new motor and tranny in few days ago so money is tight at the moment. I went ahead and ordered a 450 with a 5 gallon and I'm gonna to order another of each when im ready to do the back. I just ordered the 2500 baggs cause I didnt want to cut like hell to fit any other in since I never bagged one before, maybe I'll re-do it later cause with the wheels I have I dont believe I will be able to run shock :(
#20 ·
what the hect are those? I would't put those cups in my truck. personally i would have gone with the 380comp, i usually run my tank around 220psi.
