I need a set of conversion studs for 98 heads. should be 3/8 x 10 MM Anyone know where to get them? Running comp pro mag rockers. I need to get a set here ASAP. Anyone help with some part numbers, Im SOL till monday it looks like
Comp cams used to have them i think, I looked into it a couple years or so ago and they had them then. I didnt have much luck with Jegs or Summit understanding what I was trying to do.
im sure they are 10 mm. I can get a set from summit for a 60 degree v6 that are 1/4 inch shorter than the 8 mm ones i have, but i cant get them till tuesday
yea, thats what im looking at, gotta have em NOW! so....took the studs out of an older 2.8 and machining the tops down to 3/8 hope it works, at least so i can get the truck on the trailer tommorrow night
