fusing alternators
780 views 12 replies 4 participants last post by  therule546
so i am going to run a buss bar between my batteries and have my alternator wires go straight to that should i fuse my alternators to this buss bar or no?
#9 ·
Check out your local welding supply store man. They should be able to hook you up with some nice flexible 4/0 for under 5 a foot and lugs for around 1.79 a piece.
But yeah if you are gonna run 1/0 id run 3-4 runs for power, Your relocating all of the batteries to the bed right? If so Id run 3-4 runs straight to the frame too.
Im assuming your still planning on runnin the T40001 and an amp for speakers, and you have other power accessories in the truck right? Should be absolutely sick man, I am jealous.
#13 ·
Im not visualizing what you are saying very well.
If ALL of your batteries are in the bed, and there isnt one up front, then your best bet as far as a good ground wit low resistance would be to keep it very short and sweet, and ground it to the frame.
Now if you had a battery up front as well, you may want to run equal length runs to the front. This is what I have. I have one battery up front and two in back, 3 runs for power, 3 for ground.
