Drop blocks and vibration
1.2K views 16 replies 5 participants last post by  grndscrpr03
I just installed 4" drop blocks on my extended cab s10. Im bagged in the front. So I took it for a test ride. When I take off from a stop, I feel this vibration then it goes away. I think its from the driveshaft. Any way to fix this?
#7 ·
yeah? sometimes the angled blocks are not enough and shims still need to be added, if even more than that is needed then you can get the driveline kit from JTR that includes carrier bearing spacer, tranny mount spacer, and shims. It all depends on how bad your angle is off on what you will need to correct it.
#16 ·
I have a 95 Ext cab with spindle / spring drop in the front and 3" block and removed one leaf in the rear. I have a shimmy problem at take off also and it goes away after about 10-15 MPH. I just bought the truck and trying to find out what the angles should be to cure the problem. It has 3" non angled blocks in the rear. Here is a pic of the truck also just for kicks:
