draining upside down tank
1 reading
1.4K views 27 replies 10 participants last post by  hamagc
what would be the easiest way to drain a tank thats mounted upside down? i believe the drain plug is on the top of the tank.
#8 ·
lol on a serious note, can i use like a gas siphon to do this? lol how can i gauge how much water might be in the tank? i think it's only rained like 3 or 4 times since i bagged the truck months ago. i don't run the compressor when it rains. but from what i understand it can still pull water from the air into the tank. lol will this evaporate in the summer?
#11 ·
it sure dose. but the air brake antifreeze will stay in there for awhile.just put in like 2 capfulls.you can get this stuff at napa and its only 5 bucks a quart.it also lubes all your seals in your valves.i put some in my truck back in december and its still there but i put alot in.
#22 ·
Do you have a water trap?
I didn't have a water trap on my old setup, and after 6 months.. there was a LOT of water in there .. Never knew exactly how much could go through. On my new setup, I bought all new tanks.. I have a water trap, and I drain it about once a month, and theres usually a lot in it (1/2" SMC)
#28 ·
i'm lucky if my compressor kicks on once a day. i'm not that switch happy yet as i'm only bagged up front. i'm replacing one of the bags this weekend. i'll drain the tank then and see how much water is in there. i haven't drained it yet since i bagged it in early december. i'll post how much water i get out of it.
