Why dont ya just hook a ****ing block to a linear actuator and wire it to a momentary switch inside your cab...... Make a bracket to hold the actuator and another bracket for the block. You can get a cheap ass actuator at
www.spal.com and they exert a good amount of pressure..Good enough to get some sparks, but youll never get the same results as you would if the bitch was bagged :haha:
Or just Bag the rear end and leave the front! But if you wanna do it cheaply, you can just build simple bridge and cheap ass bags. Buy 20ft line and fitings, but instead of hooking them up to a Tank and a compressor, put like a, i dont know how to explain it, but on a car tire there is the chuck where you put air in.(where you fill the tire).. You can buy those specially made to fit onto air hose line. Buy 20 feet of line for each bag and run them inside of your cab. Bring a screw driver and when you want to drag, let out the air by pressing the little thing inside the chuck and drag that bitch. But leave it down untill you can get home to fill them back up
) That probably made no ****ign sense :rotf::rotf::rotf::rotf::rotf::rotf::rotf::rotf::rotf::rotf::rotf::rotf::rotf::rotf:
