Do it yourself o2 simulator
219K views 179 replies 86 participants last post by  s10xtremist
After a search I found that http://www.rodney.chalker.com/o2_simulator.htm
had a way to make your own o2 simulator. However, that site is down and I was wondering if anyone has those directions or know how to do it using a resistor.
#131 ·
Yes. It'll work just as good.
#139 ·
yes, down stream only.
the pre-cat o2 read rich/lean of the eng. disabling them will cause major driveability issues.
#142 ·
your 98 has an o2 after the cat or should. DO NOT MESS WITH THE ONE IN THE MANIFOLD. only the one down stream of cat.
#147 ·
I put one on my 99 blazer when i gutted the cat on it. SOME on here say they need 2 to keep the light out and some say 1 works. SO it looks like 1 will work fo ryou.
#157 ·
ok i got the 42002 non fouler last night and attempted this, but as i discovered i only had wood drill bits and attempted to use them but no go i messed it up. so then i chopped the o2 back and it screwed in put it all together and it didnt work.
today i bought another o2, 1/2 metal bit, and new fouler. this time i drilled it right, and the new sensor fit perfect i even applied anti-seize to all the threads im hoping it works. i got it all together and now battery is disconnected will it reset the codes? how long should i leave it off?
