Digital dash
2 reading
1.8K views 11 replies 4 participants last post by  orrprosegaming
Does anyone make a analog dash to digital dash wire adapter
#4 ·
My understanding was that you’re going from mechanical converted to digital and need electrical puls generated signal for digital display …
This will connect to transmission where speedometer cable come out..
Do you still need the speedometer cable???
#11 ·
I don’t think so. Only because the female side that would normally be the cluster isn’t a standard connector housing. I’ve used post-88 radio harnesses and adaptors and just pigtailed a digital dash connector for the extra length. It’s a lot of crimping but its a nice small connector. The housings are everywhere in junkyards and the pins are readily available from mouser and elsewhere.
Those pins for the analog dash I think are the same as the pre-88 radio connector, and I don’t think they’re made anymore so it’s a dead end.
