Hey everyone. This is probably going to be a wild goose chase, but here it goes. It is getting into the single digits in Upstate NY (sometimes below zero) and I am having weird brake issues. Sometimes the pedal is harder, sometimes it is softer. It usually stops about 1" above the gas pedal. Sometimes it can go a little bit lower if I am driving fast and I hit the brakes for the first time in a while. Sometimes the car stops on a dime, sometimes it takes a bit longer. There is just no consistency. My brake fluid was overfilled a few weeks ago. Now the fluid is at the MAX mark on the reservoir. Is the cold weather causing all this? Over the past year, I have had all 4 calipers, rotors, pads replaced along with the master cylinder (new) and the left front, rear and part of the right front line (all of them pass through the front left wheelwell). Also all 5 hoses have been replaced. I had 2 brake failures in NJ in one weekend last May caused by a jammed caliper that wore the pad completely out and caused the pad backing plate to hit the rotor. The shop down there replaced the master cylinder after the first one for about $400.
