4.3 auto to 5 speed out of late 80's camaro
969 views 5 replies 6 participants last post by  seafarer12
I want to change my 01 noma to a 5 speed and im wondering what would i need other than the bell housing, clutch assy. master ,and slave cylinders and line
do i have to change the gauge cluster for the 5 speed being i have digital gear indicator? And if i swap the gauge cluster do i need any sensors for the tranny? thanks
#4 ·
Pedal assembly from stick shift s10. trans harness, liek mentioned pcm reprogram. I have everything to put a t56 in my truck, lt1 trans, flywheel, clutch assembly, harness, pedal assembly, clutch master, manual trans driveshaft from similar s10, and cross member.
