Anybody know where to find a delay timer for a 12 volt system. We had them at work for the conveyor systems, but those were all 220. I need something that will keep a relay closed for about 10-15 seconds after it has received it's signal to open.
It's going to control an electric fan for my compressors. The fan will turn on when the compressors turn on, but I want the fan to run an additional time after the compressors have shut off. Otherwise they would bake in the enclosed environment.
ok so you want the relay to stay ON for a time after the signal is removed? by using a resistor in series and then a cap in parallel, the relay wont click until the cap charges up and then it will keep the relay on for a bit more after the signal has stopped
