I just bought a 1999 Chevy Blazer 2 door 2 wheel drive. Got it for cheap cause the guy said he didn't have the money to replace the fuel pump. It started and ran smooth at idle before i bought it, but would die when you gave it gas at around 1000 rpm. I drove it a few blocks home but couldnt go over 10 mph. Next day i figured id change the fuel filter to see if that would help and it didnt. I bought a new fuel pump and put it in and it does the same thing. I thought maybe the new pump was weak so i put a fuel gauge on it and it read 60 psi when i turned the key and 55 when it was at idle. While it was running i unpluged the mass air flow sensor with no change. Plugged that back in and unplugged the throttle positioning sensor, still does the same thing. Then i swappes the map sensor from my 96 blazer and it still runs the same. Bout outta ideas other than tune up or injector issue. Any ideas?
