I went and got the rubber brake line that goes from the caliper to the stainless steel line, and when I go to bleed the brakes, fluid leaks out of the caliper!! I have no idea what the fock to do! I have tried everything, I even tried using two washers because someone on here told me to only use one, but that didn't work. So I tried fliping the part that goes do the caliper around with the hole on top but that didnt work. Right now the little hole in the part that the banjo fitting goes through is on the bottom, is this right?? Some one please help. Here are some pics. The red circle shows where it is leaking from.
