1 - 11 of 11 Posts
Squeek
Well i bought a set of projectors and finaly got around to installing them and the angels eyes don't work!. I remember reading on the install paper (before it blew away) that there was supposed to be some sort of resistor or something on wire for them to work. well i pulled the loom back and there was nothing anywear. can some one tell me what that resistor or what ever it is, is supposed to be?
thanx
Squeek
thanx
Squeek
Splice the angle eye power wire to the power of your low beams..That's it. Some run it to the turn signal, but it's looks gay to me. No resistor is needed
Discussion starter · #3 ·
hmm well i pluged it in the low beem before like you said and i didn't get anything outta it... but thanx on the no resistor need part
Squeek
Squeek
If you used a splicer, make sure it has a good contact. Also make sure you are tapping into the power not the ground.
Discussion starter · #5 ·
yea i guess i should check that better hunh? I'll work on it tomarrow
Discussion starter · #6 ·
WOW am I an idiot! they just weren't bright enough during the day for me to see! sorry for wasting your time
Squeek
On yours, did you switch over the bulb in the projector housing to a high-beam bulb? I installed mine a couple nights ago and didn't want to cut my factory wiring so I modified a low beam bulb to work in it. Just curious as to what you did on yours and how you did it.
Discussion starter · #8 ·
GOOD NEWS you don't have to cut factory wiring! go to you auto parts store and and buy 2 new high beam headlight harness's, some t-taps and some male wire connectors! i'll try and get a pic from my cam if I can
Squeek
Squeek
glad you got it to work..should've checked them out at night.lol
Discussion starter · #10 ·
yea well i thought they were brighter... shows what i know!
Squeek
i have two sets of high beam lights on mine.. i just cut the plastic groove from inside the high beam and it works fine :D
1 - 11 of 11 Posts
