I have a 2002 4.3L crew cab Sonoma 4x4
and it has decided to loose power and shut off on me multiple times now. I changed the distributor as the old one was really bad. And that seemed to help for 1 drive. But I went to leave work today and it decided it would start to die as I tried to accelerate. It also would loose power faster if I turned on my turn signal or hazards..
it did completely shut off. And when it started to shut off it said check gauges and the oil pressure gauge dropped to 0
I just topped up its oil this morning as it does burn and leak oil.
we checked the voltage of the alternator a few weeks ago when it first had this issue. And it seemed to be fine.
it recently got a new battery as well, back in October/November
does anyone have any suggestions on where I could start next for trying to fix it.
UPDATE
Put a new fuel filter in. Did not help.
After putting the filter in we tried to take the truck for a drive. Pedal down to the floor truck would bog down and only go 5-10kmph. And loud popping sounds would come from my exhaust, I do have a cat code as well. we are planning to check my o2 sensors tomorrow at lunch break to see if the cats are clogged.
update 2
Removed the cat - cat had no catalytic insides. It was empty. We scoped into the resonator. And that was also empty and we got all the way through. (Picture of empty cat below)
Tried to take truck on a test drive. I didn’t have alot of time to check it out. But it does seem to act up at about 3000rpms. It got sorta shaky at that point. I’m not sure about any popping sounds as I have not put a pipe in yet. So it is obnoxiously loud exhaust sounds now 😅
The other day we had a snap on code reader attached to the truck. It said that everything was working properly, fuel pressure was fine, no misfires nothing. So we are at a bit of a blank… I’m not sure where else to go…
it only seems to struggle when the truck is in drive and is under load… I can rev it fine in neutral with no issues.
UPDATE
update 2
