good day
I have a 98 chevy zr2 blazer and i want to do the quad mod so that all 4 lights come on a couple of questions does it make a differance which side you do the mod on and 2 do you have to disable the dhl and ahl to make these work i bought a realy kit for the older chevy full size truck so i thought i could use it but apperently it does make a differance this is how i wired it up working on the passenger side the wires that come with kit are black red green brown
so this is what i did
#85 of relay to ground
#87 of relay yellow wire of low beam
#86 of relay purple wire of high beam
#30 of relay went to brown wire on the park light down on the turn signal and not on the side marker light but it didnt work i did was blow the park light fuse out can somebody please help me im up late so ill be checking back every so often i know this is old question but im new here and sorrry for the long post
:haha:
the youngest has been
wire it like this
pin 86 ground
pin 85 green/white high beam trigger of headlight plug
pin 87 ground
pin 86 yellow wire, low beam switched ground
thank you tippman was looking at the way you wire it what do i do with pin 30 and you have pin 86 listed twice is that correct just checking
Sorry, brain fart on my end the last one should be pin 30. Should be the yellow.wire.
